How do I generate a random integer from 1-5?
 If I use random how do I convert it to an integer?
Message 1 of 26
(79,321 Views)
check out the conversion palette under "Numeric->conversion"
Regards
Guru (CLA)
Message 2 of 26
(79,310 Views)
For a Random Interger from 1 to 5 you do something like this:
Edit: I just realised, that the chances for every Number are not the same, so my version is kind of unusable for statistically correct purposes.
Its too early in the morning 😉
Edit2: Also I realise further, that my version won't output 1-5 but 0-5 so it is not even what you wanted. D**n what did I do 😄
Cheers
Message Edited by Pattos on 01-20-2010 01:17 AM
Message Edited by Pattos on 01-20-2010 01:21 AM
Pattos
LabVIEW Gretchin
Message 3 of 26
(79,309 Views)
Could you just use a +1 increment after the multiplication? What does the I32 do exactly?
Message 4 of 26
(79,301 Views)
Accepted by Laudie3a
"To I32" converts your floating point number to an integer, as you specified in your first post as requirement. 😉
Here' a version that gives all 5 numbers with equal probability. Instead of explicitely converting to I32, I use the output configuration of the +1. Same difference. 😉
Message Edited by altenbach on 01-19-2010 11:39 PM
Message 5 of 26
(79,291 Views)
dear altenbach,
just some "additional" inputs to make it configurable... please kindly comment and advise. Thanks!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 6 of 26
(79,275 Views)
A similar one here
Ian F
依恩与LabVIEW
Message 7 of 26
(79,245 Views)
Wouldn't you have to multiply times 4 vs 5. If the random number give you a one then you would get 5 and add 1 to it giving you 6.
Tim
GHSP
Message 8 of 26
(79,216 Views)
Tim
GHSP
Message 9 of 26
(79,214 Views)
No aestet, Altenbachs solution is perfectly fine.
The dice generate a Number between 0 and 1 (Not including 1!!) Multiplied by 5 that is a Number between 0 and 4.999999.
The next triangle always rounds the Number down, so that you can only get 0,1,2,3 and 4 everything with equal propablity.
Plus one you get 1,2,3,4 and 5.
Pattos
LabVIEW Gretchin
Message 10 of 26
(79,208 Views)
