How do I get rid of unused dependencies?
Hello all.
Tearing my hair out here, (what's left of it). We have some very complex monitoring software written by someone else, many years ago, and now not available. I needed to turn the analysis section of it into a small standalone application so, rightly or wrongly (the latter, I suspect), I did a slash & burn on all the unwanted parts of the code until I was left with just the bit I need.
I have now ended up with a nice little working application, but it has hundreds and hundreds of dependencies, classes and sub vis that are no longer there.
In desperation I cut & pasted the main loop into a new vi and, if I make a new project with the vi in it, the dependencies are still there, despite there being no reference to them!
I'm afraid to say I don't understand why. The new code is tiny and has only one sub vi, no reference to any of the other 400 dependencies. I'm stumped. How to I get rid of the dependencies?
As I say, this is only a part of the application, but the whole thing isn't much bigger. vi is attached.
Thanks for any help.
Andrew
Message 1 of 12
(5,073 Views)
Classes and Libraries could be one of your issues.  If even 1 VI or control from a library or class is used, then entire library or class is also loaded and will show up as a dependency.  This would indicate that it was not written with enough modularity.
Message 2 of 12
(5,064 Views)
At least it is narrowed down to the subVI that you didn't include.  😉
Bill
CLD
(Mid-Level minion.)
Message 3 of 12
(5,060 Views)
OK, sorry, I should've said, it doesn't make any difference if that sub vi isn't there.
I have taken it out and posted the new version.
If I now create a new project from this vi, it has over 100 dependencies, despite there being hardly anything in the vi now, no sub vis that I can see.
Message 4 of 12
(5,043 Views)
Accepted by topic author ASH2020
Odd, I see nothing but dependencies on vi.lib as expected.
Bill
CLD
(Mid-Level minion.)
Message 5 of 12
(5,040 Views)
This is what I see. Not hundreds of dependencies - just the few vi.lib dependencies that I would expect.
Maybe you should zip and upload your entire project folder so that we can see what's going on.
Message 6 of 12
(5,030 Views)
Phew, yes I see what's happened. Version 9 was hanging around in the background somewhere and when I created the project it added V9 and V10. V9 was the one that must've had some references to the class in it.
Sorry about the waste of time. I should be able to add modules in until I find the rogue one. Thanks for the help all.
Message 7 of 12
(5,028 Views)
It's not a waste of time.  Not coming here and not finding a solution - now that would have been a waste of time.
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(5,024 Views)
I agree with billko.
Message 9 of 12
(5,022 Views)
Thanks again crossrulz, Bill and John.
Sometimes it just takes a little discussion and working through to see the light at the end of the tunnel.
Although sometimes, as they say, It's some **bleep** with a torch, bringing you more work! 🤣
Much obliged though, I think I can sort it from here.
Cheers
Andrew
Message 10 of 12
(5,005 Views)
