How do I make the NI Activation Wizard window not popup during install?
During my install, I don't want the NI Activation Wizard window to appear. I would like the install process to run silent.
The activation process shall occur when the user goes to the license manager only, not during install. How do I do so?
I tried to play with the setup.ini file sitting next to the setup.exe but only the Eula and license agreement windows disappear.
Please let me know.
Thank you
(3,812 Views)
Please take a look at this thread and see if it helps.
Cory K
(3,805 Views)
Hi Cory,
I am not referring to a LabVIEW  install from the LabVIEW CDs but for an install of the application I create from the LabVIEW project installer tool.
I would like the install of my application to be silent and the install folder doesn't contain the template_spec.txt file.
Any other suggestion?
(3,789 Views)
Raph:
This KB might help out. It outlines the method for setting up a custom installer that will also install the run-time engine silently. This should be applicable to other included packages as well.
Caleb Harris
National Instruments | http://www.ni.com/support
(3,752 Views)
