How do I programmatically create an Enum from an array of strings?
How do I programmatically create an Enum from an array of strings? I'm trying to programmatically build an Enum containing a list of tests to execute, based on the user's product selection.
(10,968 Views)
It is not possible to define the values of an enum at run time.
It is possible to define the strings associated with a ring.
If this is a one time event that needs to happen at development time then push your strings into a ring control then right-click and doa replace then navigate to an enum.
Just trying to help,
Ben
(10,966 Views)
Accepted by Rchrd
My Variant To Control code on LAVA has a demo VI to convert an array of strings to an enum.
Ton
Message Edited by TCPlomp on 21-09-2009 10:54 PM
My LabVIEW Ideas
(10,946 Views)
