How do I stop the pop up message: Do you wish to add the directory ___ to your search path?
After installing LabVIEW 8.6.1f1 on a new PC, every time I choose one of my VIs via the Select a VI.. palette, I get a pop up message saying, "Do you wish to add the directory "P:\CWalker\COREYs LabVIEW projects\Phoenix subs" to your search path?"
I have already added "P:\CWalker\COREYs LabVIEW projects\Phoenix subs" in the VI search path option, and restarted LabVIEW, but the message will not stop popping up.
Message 1 of 12
(4,705 Views)
Hi jcoreyw1969,
How did you add the directory to your search path?   Did you following these directions?
--Starla T.
Message 2 of 12
(4,670 Views)
Accepted by jcoreyw1969
Yes, that's how I added the directory.
Since then, I managed to stop the popup message.
Evidently I had removed some of the defaults, such as "<topvi>\*" from the VI Search Path option, and that caused the popup message.
Thanks!
Corey
Message 3 of 12
(4,662 Views)
is there a way to avoid the above mentioned dialog box without having to add the "<foundVI>\*" or "<foundVI>\*" item?
Thanks!
Message 4 of 12
(4,141 Views)
aschipfl,
Just to confirm, you have explictily added the directory in question, correct?
Message 5 of 12
(4,091 Views)
no. This is my situation:
In my search path, there are the following items: <topvi>\*, <vilib>\*, <userlib>\*, <instrlib>\* and the "resource" directory from the application path.
As soon as I add a sub-VI (via the 'Select a VI...' palette item), which is not located in one of those paths, the "Do you wish to add..." dialog box appears.
(If I click No, the same dialog appears for all such sub-VIs; if I go for Yes, the Options window comes up.)
When I add the <foundvi>/<foundvi>\* item(s) to the search path, the dialog does no longer appear. But I do NOT want <foundvi> to be in the search path.
And I don't want this dialog box to show up every time... Can you please help me??
Message 6 of 12
(4,070 Views)
Do you get the same dialog when you have "Use Default" checked in the paths section?
When I add a VI using the method you suggest, I do not get the dialog.  I'm curious to see what settings we have that are different.
Are you using LabVIEW 2013 SP1?
Message 7 of 12
(4,045 Views)
No, when "Use Default" is checked, I don't get the dialog.
But using default means to have <foundvi> in the search path which I do not want...
I am currently using LabVIEW 2013 (Version 13.0f3, x64).
But I encountered the same behaviour also with former versions like 8.5.1...
Message 8 of 12
(4,039 Views)
why are you trying to avoid having <foundvi> in your search path?
Michael L.
Sales Engineer
Message 9 of 12
(4,016 Views)
I always want to know where any (sub-)VIs are loaded from.
There are only two permitted locations for me: the project path (<topvi>) and shared libraries (<vilib>, <userlib>,...).
<foundvi> could lead to the problem that a wrong copy of a sub-VI is linked...
Message 10 of 12
(3,986 Views)
