How do I vary the voltage of a DC power source in a sine pattern around a certain voltage?
Jeez, that was silly.  I'm still have a read timeout error occur, and the voltage isn't being ramped on my actual instrument.  The program seems to not be telling my instrument to give a sine wave voltage output.  It's only setting the instrument at 15 V instead of oscillating the voltage in a sine pattern.  I just really need this VI to work, then I can take the tutorials.
Message 11 of 21
(1,586 Views)
When you add the 15v it needs to be a single scaler numeric constant rather than an array. The array you added only contains one element so your output is also just the one number.
If you put a graph indicator on your numeric data you will see what signal you are sending. Adding extra indicators to your code at the development stage can be a big help in solving codeing problems, you should also check out using the Probes.
Message 12 of 21
(1,585 Views)
I reeeally appreciate your comments, however I still have a VISA Read timeout.  And when I run my VI, nothing shows up on the waveform chart.  This may drive me up the wall.
Message 13 of 21
(1,578 Views)
You're taking an array of data, turning it into a string, and basically making a very long string of commands to throw at the instrument.
Is it possible you are overwhelming the input buffer of the instrument?
Also, a lot of times instruments require some sort of termination character when you send it a command such as a line feed and/or carriage return.  I don't see that in any of the commands you are creating.
I suggest reading the manual for the instrument and start working with some basic simple, single commands and get that working before you start building up into larger things like working with arrays of commands.
Message 14 of 21
(1,570 Views)
I should have said a simple scalar, rather than 'single'. Here's what it should look like:
Message 15 of 21
(1,569 Views)
You have not followed the suggestions which have been made. You can add a scalar to an array. The result is that the scalar is added to every element of the array. What you did was to add a one-element array (with value 15) to the sine array. The result is a one element array. When two arrays of different lengths the result is the length of the shorter input array.
This is what you have: (Note that the constant below the x+y indicator is a constant with teh same values as the indicator.)
Here is the way to add a scalar to an array.
Lynn
Message 16 of 21
(1,563 Views)
Thanks Lynn, my problem now is whenever I try to wire a constant to the y portion of the add function, it automatically makes it a 1D array, and I'm not sure how to add a scalar.  I'm looking through the LabVIEW book now to figure it out, but not finding much...
Message 17 of 21
(1,534 Views)
Pull a constant from the numeric palette first, then connect it to the + function.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 18 of 21
(1,532 Views)
I'm still getting an error message, but now it's a different one.  It says there's a problem at the VISA Configure Serial Port, but I know I have all of the correct parameters for my instrument.  In fact, now the sine function is ramping, but only from 15 V to 15.4 V, then I get this error message and the VI stops.  My 15 V constant on the Add function is not the same data type as the array, maybe that is the issue.  I know the serial port is configured correctly.  Maybe it would help if I put a Bytes At Port on my VISA Read function?  I've heard some programmers say this is correct, and some say that it creates more problems than it solves.  The error message and VI are attached.
Message 19 of 21
(1,528 Views)
You can't add a number to a string, which you do in two places. You have to convert the number to a string and concatenate the two strings.
Cameron
Message 20 of 21
(1,524 Views)
