How do you add 2 physical channels from the same control?
Is there a way to do this? or do I have to add another control?
I currently have one physical channel wired to Daqmx Creat Channel.vi, but I need to add a second. How can I go about doing this?
Also, if this is successsful, how do I differentiate the data on separate plots after the Daqmx read vi?
Thanks in advance!
Message 1 of 42
(5,420 Views)
Use a second DAQmx Create Channel.  There is an input for Task.  Wire the task from the first one into the second.
As far as the DAQmx Read goes, the first channel you add is the first waveform, data point, or row, depending on how you do the read.
Message 2 of 42
(5,412 Views)
And you only need a second create channel if you have a different type.
Message 3 of 42
(5,405 Views)
Thank you both for the reply. Both my channels will be recording a voltage input, so do I still need to add another create channel?
Message 4 of 42
(5,324 Views)
Only if the second channel has different min/max, configuration (i.e. rse/diff) settings.
Message 5 of 42
(5,321 Views)
They both have the same max/mins. One signal is coming from a Load Cell, and the other is coming from a LVDT displacement measurement device.
Since I don't need 2 create channel vis, is there a way to include both channels in the single physical channel control?
Message 6 of 42
(5,318 Views)
Of course. You can click on the channel control and select browse. You can manually enter multiple channels as well. The syntax is Dev1/ai0:1 or Dev1/ai0,Dev1/ai2 for non-consecutive channels.
Message 7 of 42
(5,305 Views)
Thank you, I figured out the multiple channels. Of course though, I now have a new question. I am looking to output two separate plots of the voltages for my load cell and LVDT. Which Daqmx Read setting would be the most appropriate for this situation? I tried reading through the detailed help, but it wasn't clicking.
Also, do I have to use the "split signal" vi to place both columns of data into an array?
Message 8 of 42
(5,298 Views)
Your DAQmx Read has to be set for nchan.
If you are requesting nsamp now, you are getting data in an array. You have not said what you're current setting is. You might get back a 2D dbl array or a 1D waveform array. I would recommend the index array function instead of the split signal function if you need to separate the channels. The split signal function will create the evil dynamic data type.
Message 9 of 42
(5,281 Views)
I have learned this the bad way! I will give your recommendation a shot! Thanks
Message 10 of 42
(5,278 Views)
