How do you add 2 physical channels from the same control?
I tried using the the index array feature, and cant figure out where to connect the output.
I am trying to read the data into multiplt columns using the "array to spreadsheet" vi, but I don't know the proper sequences of Vi's between the Daqmx read (Analog 1D Wfm Nsamp) and the "array to spreadsheet" vi.
I attached my VI, but it is version 8.2 so it may be completely different
Message 11 of 42
(1,547 Views)
Can you attach an image? I'm posting from my phone.
Message 12 of 42
(1,536 Views)
Here you go!
Message 13 of 42
(1,533 Views)
Since you are acquiring a waveform data type, you might be better off with the export waveforms to spreadsheet file. Otherwise, you would need to use the Get Waveforms Components to get the y array. You'll lose the timing information though.
Message 14 of 42
(1,528 Views)
I'm sorry, I think I was misunderstood. The data doesn't necessarily have to be written to a spreadsheet. A .txt file is 100% fine, I just need it to write in columns of data for each voltage input. Does this alter your latest advice?
Message 15 of 42
(1,523 Views)
Not really. The function I mentioned will create a text file. I don't think it's a good idea to throw away your sampling information but you are free to do that with the get waveform components to get just the y array.
Message 16 of 42
(1,518 Views)
By "sampling information", are you referring to the sampling rate?
Message 17 of 42
(1,515 Views)
Yes. This is generally pretty important information if you need to do any post processing.
Message 18 of 42
(1,511 Views)
Shoot. The sampling rate is very important in this VI. I think I am having the most difficulty understanding exactly what is being output from the Daqmx Read Vi. Are 2 sets of data being output? If so, I just need to be able to somehow put those two datasets into columns in a .txt file.
Right now I use this sequence (it is not working):  Daqmx read>>>build array>>> array to spreadsheet String>>> write to text file
When I tried including the "get waveform components", the output from Daqmx Read wasnt compatible with the "get waveform components" input
Message 19 of 42
(1,508 Views)
You would have to index the waveform array first. That could be done by simply placing it inside a for loop. The function I mentioned doors all of that for you with a header that includes the sample rate. To use wire to spreadsheet, you would have to create your own header.
Message 20 of 42
(1,505 Views)
