How do you refresh html source?
I'm using the VI below for accessing the internet and pulling data from certain websites. The problem is that when I run the VI, it doesn't automatically refresh the data from the websites, so I'm getting old data.  I tried using the "refresh" option, but couldn't get it to work without giving me an error.  I'm using LabView 7.1.
Message 1 of 8
(5,650 Views)
Hello JFrakes,
Here is useful website with information on ActiveX internet web browsing. Attached on this page is an example that utilizes several control buttons including a refresh button.
ActiveX Internet Web Browser Using Event Structures in LabVIEW
https://decibel.ni.com/content/docs/DOC-19168
Applications Engineer
Message 2 of 8
(5,630 Views)
Paul-B,
I'm using LabView 7.1 and so it's not compatible with your VI.
The VI I posted earlier has a method called, "refresh."  But when I wire it up, it gives me error code 97.  Maybe I'm wiring it wrong or need to put it in a loop?  Unfortunately, I can't figure it out.
JFrakes
Message 3 of 8
(5,625 Views)
Hello JFrakes,
Here is a screen shot of the refresh event structure from LabVIEW 2011. You can try to replicate this or structure your refresh button around this example.
Hope this helps.
Message 4 of 8
(5,594 Views)
That helped.  But I had to add the time delay of three seconds in each frame of the sequence structure to prevent the error.  It refreshes the page each iteration, but after a series of 800 URLs, it takes nearly five hours to run.
Message 5 of 8
(5,576 Views)
Hello JFrakes,
Here is an example screen shot for a custom URL.
Hope this helps.
Message 6 of 8
(5,554 Views)
Accepted by JFrakes
I finally solved the problem.  You need include a while loop to measure ready state before and after the refresh command.
Message 7 of 8
(5,535 Views)
Taking from that example, can you explain what's happening with the refresh timing here?
How can I make it smoother without using timed or parallel loops?
If I leave a web browser open on my desktop it refreshes without drawing a blank (i.e. just the changes are updated rather than the whole page). Is that possible?
Many thanks
Graham
Message 8 of 8
(4,487 Views)
