How does NI 9411 card convert the digital input pulse given to output rpm?
I am measuring the shaft rpm using the encoder and feeding it to the 9411 card.Can the 9411 card display the shaft rpm? How the card can do this conversion?Should I use any other component to decode the digital input pulse?
(2,743 Views)
Have you tried enough searching, here and there...??
1. Check page # 12 of this manual.
2. How Do I Use a Quadrature Encoder with My Data Acquisition Board?
3. Encoder Measurements: How-To Guide.
Edited:
4. NI 9411 Pinout.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,736 Views)
Thanks for the link which you provided.It was useful.
(2,712 Views)
So if it has solved your problem, you can mark my earlier reply as solution.
(2,709 Views)
