How much current does cDAQ 9178 chassis need for USB communication?
How much current (maximal) does cDAQ 9178 chassis need for USB communication?
I have a self-powered USB hub with four cDAQ 9178 chassis. The problem is that no other USB (self-powered) devices are not recognized on the hub. I want to know how much current is consumed by the four chassis.
Thank you,
Tatsuya
(4,715 Views)
Accepted by tatsuya1
Hi Tatsuya
As described in cDAQ 9178 SPECIFICATIONS:https://www.ni.com/docs/en-US/bundle/cdaq-9178-specs/page/specs.html
The input voltage range is 9 to 30 V and the maximum required inputpower is 15W.
At the same time ,the power consumption from USB is 4.10 to 5.25 V with 500 μA maximum.
May it help you.
Regards!
(4,664 Views)
Thank you Canon_Fan!
(4,639 Views)
