How much is a char in a string
Maybe you can increase the lenght of the string subset by (m-1) while keeping the index positions the same (where "m" is the lenght of the matched string). 😉
Message 21 of 27
(1,403 Views)
I do not understand what you mean Smiley Sad
"increase the lenght of the string subset by (m-1), while keeping the index positions the same"
where do that ? in the code of "Count or parralel Count" ?
in any cases, this will not prevent to split the main string in the middle of a substring
I search and I count the substrint "ABCD" ...
main string : zzzzzzzzzzABCDzzzzzzzzzzzz
split : zzzzzzzzzzAB | CDzzzzzzzzzzzz  (ABCD will not be found)
sorry, i don't understand your comment  (Maybe you can increase...)
Message 22 of 27
(1,386 Views)
You simply make each subset longer so there is a small overlap. If the search string is 4 characters, make the subset 3 characters longer (characters shown in red). Now you get exactly one match (underlined), no matter where the cut is (either in the first or in the second substring).
For example like this:
Here are some examples.
zzzzzzzzzzzz|ABC
            |ABCDzzzzzzzzzzzzzz
zzzzzzzzzzzzA|BCD
             |BCDzzzzzzzzzzzzzz
zzzzzzzzzzzzAB|CDz
              |CDzzzzzzzzzzzzzz
zzzzzzzzzzzzABC|Dzz
               |Dzzzzzzzzzzzzzz
zzzzzzzzzzzzABCD|zzz
                |zzzzzzzzzzzzzzz
Message 23 of 27
(1,378 Views)
ok, understood.
an overlap of (m-1) ... yes, of course, obviously ...smart idea !
thank you altenbach
Message 24 of 27
(1,372 Views)
Q6600 - 4 core - 2.6Ghz
main string : 50e6 char
count the number of "abc"
4 core => N/C=4
N=4    C=disable  64ms   cpu 67%   0
N=4    C=1        64ms   cpu 67%  -0
N=8    C=2        62ms   cpu 64%  -2
N=16   C=4        60ms   cpu 64%  -2
N=32   C=8        53ms   cpu 60%  -7 max delta
N=64   C=16       48ms   cpu 60%  -5
N=128  C=32       44ms   cpu 55%  -4
N=256  C=64       43ms   cpu 53%  -1 max speed
N=512  C=128      43ms   cpu 53%  -0
Message 25 of 27
(1,337 Views)
by cons, with your "Count_Parallel" code, the speed  does not change
if I change "reshape array / dimesion size" and  "For Loop / C" ... it's curious.
Message 26 of 27
(1,323 Views)
This post does not provide sufficient information to be useful.
Message 27 of 27
(1,319 Views)
