How read data from txt file in Armenian letters | LabView
I want to read data from the text file where are Armenian words, but I see only Õ¢Õ¡Ö€Ö‡ Õ€Õ¡ÕµÕ¥Ö€!
How can I solute this problem without changing the config file? because I want my program to work on different computers․
(1,671 Views)
Check this link it may fix your problem Read Special Characters with LabVIEW - NI
(1,667 Views)
(1,665 Views)
(1,646 Views)
I could display Armenian charters but can't read Armenian charts from a text file.
(1,602 Views)
Accepted by Petros_Baghalyan
Hi Petros, did you manage to solve this issue yet?
The main problem is the text file is UTF-8 encoded, but when writing Unicode to LabVIEW's string controls they require UTF-16LE encoded text. The solution is to change the encoding, either of the text file itself (with Notepad or similar), or of the string once it has been read into LabVIEW. Personally I'd keep the text file as UTF-8, and only convert to UTF-16 for display. NI's Unicode Toolkit allows Unicode conversion to and from ASCII, but not between UTF-8 and UTF-16 AFAIK.
I've just published a toolkit called G-Unicode which aims to streamline Unicode handling in LabVIEW and can read, convert, probe, and display Unicode text amongst other things. Here's an example of reading the Armenian text from a UTF-8 encoded file and displaying it in a LabVIEW string control:
The example VI is attached and requires the G-Unicode toolkit (available on VIPM or github) and LabVIEW 2020.
(1,517 Views)
