How to Build a VI that generates a random number between 1 and 80 ....Help!!!!
Divides the random number by a number specified in the front panel.
If the inputted number is zero, the VI program should turn on a LED in the front-panel to indicate a divide by zero error.
(6,782 Views)
multiply the random number by 80 followed by ROUND TO NEAREST vi
Somil Gautam
Think Weird
(6,768 Views)
You only need the random number to multiply 80. The random number produces a point number between 0 and 1.
Regards
MY
(6,763 Views)
Message Edited by Baji on 09-21-2009 03:10 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(6,755 Views)
Accepted by edwardty2009
Hai edwardty2009,
Welcome to the forum.
Thanks for the kudos.
Is your problem solved? If so can you please mark as solution which post helps best to solve your problem.
Mathan
(6,717 Views)
One quick question Edward, was the answer just in time for your monday morning class.
Ton
My LabVIEW Ideas
(6,684 Views)
