How to Change Block Diagram Label Text Color Default
@DailyDose wrote:
nteresting you mention that, new job required an extensive eye test since we work with Class 4 lasers.  20/10 vision baby! .
20/x vision is just acuity for distant vision. It does not say anything about reading distance. Close distance focus ability diminishes with age (presbyopia). Glare can come from bright light (e.g. the diagram background) hitting the lens from the side then getting scattered by e.g. mild cataract (again, that everybody will get with age!). It's like the setting sun hitting your dirty windshield at an angle. Still, I trust that they did a comprehensive battery of tests, so you are probably OK (... and I have of course absolutely no idea about your age, but these things are important to keep in mind for the future). 😄
Message 11 of 23
(3,105 Views)
Well, if you must know, use something like this in labview.ini
Diagram.Background = 00FFFF7F
Message 12 of 23
(3,099 Views)
I thought the newer versions of LabVIEW had an option to choose an "alternate" set of colors, like a new color schema, but I can't find that anywhere.
Bill
CLD
(Mid-Level minion.)
Message 13 of 23
(3,078 Views)
You can follow this option to set the label colours default what you want.
Message 14 of 23
(3,061 Views)
For anyone that cares - for a block diagram I am actually finding this shade of grey to be easier on the eyes. R:231 G:231 B:231 - so basically the Front Panel grey. (gray?)
Message 15 of 23
(3,040 Views)
What's that error wire doing running behind the WHILE loop?🙄  Just saying that maybe you should be concentrating on other things than BD colors.  🤣
Bill
CLD
(Mid-Level minion.)
Message 16 of 23
(3,034 Views)
Since I use multiple versions of LabVIEW, I color them differently in order to reduce my confusion (see attachment).
Also, here are a bunch of LabVIEW  ini key for color (don't remember where I found them):
diagram.background
diagram.primColor
coercionDot
sourceCoercionDot
sourceUserCoercionDot
panel.background
execPalette.foreground
execPalette.background
cursor.foreground
cursor.background
scrollbar.foreground
scrollbar.background
blinkFG
blinkBG
menu.foreground
menu.background
menubar.foreground
menubar.background
CBoxDefaultColor
CBoxCommentColor
CBoxKeywordColor
CBoxStringColor
CBoxModifierColor
CBoxPreprocessorColor
CBoxDataTypeColor
CBoxConstantColor
MathScriptOperatorsColor
MathScriptKeywordsColor
MathScriptVariablesColor
MathScriptConstantsColor
MathScriptFunctionsColor
MathScriptUDFColor
MathScriptUnknownColor
MathScriptNumericColor
MathScriptStringColor
MathScriptCommentsColor
MathScriptIntegerColor
MathScriptDoubleColor
MathScriptComplexColor
MathScriptCharColor
MathScriptBooleanColor
MathScriptUnknownVarColor
MathScriptPluginColor
MathScriptStructColor
AllowStackVariables
MathScriptCellArrayColor
Message 17 of 23
(3,028 Views)
I'm surprised you weren't more concerned about a controlled while loop that just waits.  I just throw this on there and took a snippet.  Grey loop, green boolean, blue integer, yellow error, but no pink string. (so not a great photo)
Message 18 of 23
(3,023 Views)
diagram.background
diagram.primColor
coercionDot
sourceCoercionDot
panel.background
cursor.foreground
cursor.background
blinkFG
blinkBG
menu.foreground
menu.background
menubar.foreground
menubar.background
CBoxDefaultColor
CBoxCommentColor
CBoxKeywordColor
CBoxStringColor
CBoxModifierColor
CBoxDataTypeColor
CBoxConstantColor
MathScriptUDFColor
MathScriptCharColor
AllowStackVariables
Yes, this is way deeper than I wanted to dive.  😉  However, I thought there was an option you could set that you could select something akin to an alternate Windows theme; a preset, if you will.  But maybe I just dreamt it up.  Sometimes my reality isn't anyone else's.
Bill
CLD
(Mid-Level minion.)
Message 19 of 23
(3,019 Views)
Mr. Ko is not hallucinating (this time)
Message 20 of 23
(2,963 Views)
