How to Refresh Dependencies in the project window programmatically?
In a newly created project window (created at runtime, filled with top level VIs), the Dependencies folder is empty.
How to Refresh the folder programmatically?  i.e. mimic select Refresh on the right click menu.
George Zou
Message 1 of 10
(839 Views)
Accepted by zou
Hi zou,
Class TargetItem has a method "Refresh Dependencies":
Raphaël.
Message 2 of 10
(794 Views)
You can also just mass compile your code.
Tim
GHSP
Message 3 of 10
(782 Views)
Seems a bit excessive if you only added a file to the project programmatically.
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 10
(756 Views)
@raphschru wrote:
Hi zou,
Raphaël.
Thanks everyone.  Somehow I missed My Computer level.
Now I need to filter out NI VIs, such as DAQmx, niDMM, niScope, etc.
What is the best way?
IsSystemVI doesn't work.
George Zou
Message 5 of 10
(741 Views)
@zou wrote:
@raphschru wrote:
Hi zou,
Raphaël.
I would do it by path.  Anything in vi.lib, or anything in instr.lib in a list of defined directories (or possibly just "instr.lib\ni*", if you feel confident that you won't be creating your own directories starting with "ni" in instr.lib.
Another potential option is if you use source control, you could only include files contained in source-controlled directories.  Start with the current path, and keep going up until you find a ".git" or ".svn" in the folder or you reach the top level.
Message 6 of 10
(726 Views)
Accepted by zou
Filter out NI VIs from what? Do you have an initial list?
If you have a list of:
 - File paths ➡️ Check if each path is relative to vi.lib's path.
 - Project item refnums ➡️ Check if property "Path" is relative to vi.lib's path.
 - VI refnums ➡️ Check if property "VI Path" is relative to vi.lib's path.
You can also recursively read property "Owned Items[]" starting from your target's Dependencies item, then skip when you encounter the virtual folder "vi.lib".
Raphaël.
Message 7 of 10
(725 Views)
Raphaël.
I use Get All Descendants to get a list of VIs under Dependencies.
Compare path is slow.  Compare Two Paths.vi is not even Reentrant.
George Zou
Message 8 of 10
(717 Views)
If speed is really a concern for path comparison:
Message 9 of 10
(710 Views)
OwnedItems[] plus file extension is better.
George Zou
Message 10 of 10
(702 Views)
