How to access a Beckhoff 9000 with TCP/IP?
i´m using LV 8.5 with Windows-XP.
A Beckhoff9000 (BK9000) is connected via LAN.
What is working is, that i can ping my BK9000 in a cmd-box.
The BK9000 has also connected:
KL2134 (4 outputs)
KL2134 (4 outputs)
KL1418 (8 inputs)
KL9000 (end)
Is there an easy example of how to access these in- and outputs?
Something like
input:
- IP-address (192.168.0.23)
- module-number (1..3)
- input-number (1..4 or 1..8)
- mode (on/off)
output:
state (on/off)
Thanks for all help how to do this.
All i want to do is to enable or disable outputs and to read the state of an input.
best regards
(3,448 Views)
Hi OnlyOne,
did you see this thread?
Hope it helps. Mike
(3,426 Views)
