How to add a carriage return
Hi
How to add a carriage return after Survey Type, so that the Channel Time will start from column one.
Steve
(2,984 Views)
You could write a line feed to the end of the file after writing the ini portion.
(what is the purpose of concatenate string in the lower left?)
(2,981 Views)
Hi
I am new to the Labview. How could I write a line feed at the end of Section 2?
Steve
(2,967 Views)
Accepted by Shijie
try something like the following draft. (not tested, so modify as needed).
(2,952 Views)
It works. Thank you very much.
Steve
(2,944 Views)
