How to append data to save file without overwriting? Using create file / write to file / close file
Can you attach the "fix". (LabVIEW programmers don't understand verbal descriptions of graphical code :D)
Message 21 of 24
(794 Views)
Sure, let me go into the lab and grab it on a usb stick.
Message 22 of 24
(792 Views)
Accepted by etvg
Here is the code which can record multiple scans of the desired frequency range and output all of the data from each scan in a single file.
Message 23 of 24
(791 Views)
Clad you solved your problem, sorry had an expected visit (+ time difference).
Message 24 of 24
(765 Views)
