How to block points of an XYGraph
Hi, I am doing a labview program for a project, I use an XYGraph with options to add points, move existing ones and delete them.
I have been trying to limit the elimination of points for a few hours, because I want the start and end points(in this case 0 and 11) cannot be eliminated and remain fixed. At the moment I have not found a way to do it, if someone can help me, I would greatly appreciate it.
I attached my VI.
(3,055 Views)
Hi Aleix_C!
What do you mean with limit the elimintation of the points?
If what you want to do is nos allow the elimination of the first and last points, I would extract them, remove the relected points based on the configuration, and add the first and last points again.
(I can not download the code right now, but I would take a look if this does not resolve your doubt.)
(3,013 Views)
Accepted by Aleix_C
Just check the range
(2,996 Views)
Hi Aleix,
IF cursorindex > 0 OR cursorindex < 11 THEN
   delete current point
ENDIF
A simple case structure might help…
(2,991 Views)
Hi!
If you remove a point from Y array, you should remove it aswell from X array. I should download the code to completly understand the whole code.
(2,986 Views)
Oh yeah! It works, thank you so much!
(2,925 Views)
Thank you abarrenetxea and GerdW for your help too, nice comunity!
(2,918 Views)
