How to build an array dynamically based on content of another array?
Hi everyone ,
Let's say i have a boolean array of 6 rows (Input array) . I want to dynamically build another array (output array) that contains the indecies of the zeros/Falses in the input array. I made a block diagram for you to understand what i mean.
Message 1 of 10
(3,519 Views)
Accepted by hus_505
Certified LabVIEW Architect
Message 2 of 10
(3,503 Views)
Thanks ! . The problem is , i am using an old LabView that doesnt have tunnel mode ? How would it be like without the tunnel mode ?
Message 3 of 10
(3,493 Views)
I don't understand, where the output array is .
Also , what happens in the false case ?
Message 5 of 10
(3,470 Views)
Accepted by hus_505
The shift register output is the output array.
In the false case, the array is wired form left to right.
Are you aware of the (free) courses?
Message 6 of 10
(3,466 Views)
I don't understand either, because the output does not contain any indices as requested: 😮
Here's the correct solution (not using a conditional tunnel, i.e. for ancient LabVIEW versions only).
Message 7 of 10
(3,417 Views)
🌴😐 (:palmface:)
Should have run it at least once.
Message 8 of 10
(3,367 Views)
wiebe@CARYA wrote:
🌴😐 (:palmface:)
"Once" is statistically irrelevant. 😄
(What bothered me more about your snippet is that the integers are a much lighter blue. Why is that?)
Message 9 of 10
(3,346 Views)
@altenbach wrote:
wiebe@CARYA wrote:
🌴😐 (:palmface:)
But inf times more then none 😊
At some point I was curious what "ModernBD=True" did.
I didn't hate it so much that I turned it off, or maybe I figured it gave me a head start getting used to NXG look.
Message 10 of 10
(3,337 Views)
