How to calculate standard deviation of a certain number of points?
Hi, I have an application that I acquire force signals and pu then on a array.
I need to calculate the standard deviation and the mean each a certain number of points, 1000 for example.
I'm having problems with this, if you can help me I'd be thankful.
Douglas
(9,125 Views)
If you have the Full Development version of LabVIEW, look into the Standard Deviation PtByPt VI.
(9,123 Views)
You can also use Std Deviation and Variance.vi if you have the input as an array
(9,115 Views)
Hey thank you, but it don't solve my problem.
I have a graph of force, generating 1000 points per second, for example, and I have to calculate the standard deviation for each 100 points, for example, and display it on a graph.
If I have an array of 50k points, the array of standard deviation should have 500 points.
I don't know if you could understand me, but any help would be great.
I attach the vi to help you visualize (don't mind the mess, I'm working on it).
Thank you
(9,069 Views)
Accepted by Douglas_kilo
So you need something like this?
(9,064 Views)
Hey, thank you, I finally did it and it works perfectly!
Thank you so much!!!
(9,022 Views)
