01-17-2013 07:12 AM
Hi, I have an application that I acquire force signals and pu then on a array.
I need to calculate the standard deviation and the mean each a certain number of points, 1000 for example.
I'm having problems with this, if you can help me I'd be thankful.
Douglas
Solved! Go to Solution.
01-17-2013 07:22 AM
If you have the Full Development version of LabVIEW, look into the Standard Deviation PtByPt VI.
01-17-2013 07:35 AM
You can also use Std Deviation and Variance.vi if you have the input as an array
01-24-2013 10:20 AM
Hey thank you, but it don't solve my problem.
I have a graph of force, generating 1000 points per second, for example, and I have to calculate the standard deviation for each 100 points, for example, and display it on a graph.
If I have an array of 50k points, the array of standard deviation should have 500 points.
I don't know if you could understand me, but any help would be great.
I attach the vi to help you visualize (don't mind the mess, I'm working on it).
Thank you
01-24-2013 10:30 AM - edited 01-24-2013 10:30 AM
So you need something like this?
02-05-2013 07:39 AM
Hey, thank you, I finally did it and it works perfectly!
Thank you so much!!!
