How to change cluster-elements used in subvi´s automatically?
I have a Array of Clusters and a lot of SubVIs using this Cluster. If I change the Cluster ( f.e. thorugh adding a new INT-value to it), I need to go in all of my SubVIs and also do the same changes there. There must be an easier way to do this, but I was not able to find it out. I tried thorugh refernece, but it didnt work 😞    I was also not able to find a solution here in this forum.
Can somebody help pls?
LabVIEW 2011
(2,321 Views)
Accepted by topic author Serdj
Serdj,
I am not sure if this is your problem, but have you tried type defining the cluster?
Look here https://www.ni.com/docs/en-US/bundle/labview/page/creating-type-definitions-and-strict-type-definiti...
regards,
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,318 Views)
Thanks aCe, it looks like the solution I was looking for. I will try it out these days. Thanks a lot!!!
LabVIEW 2011
(2,315 Views)
