How to change string background colour programatically?
(7,954 Views)
Accepted by swathi
Are you talking about string indicator and string control? If so, right-click on a string control/indicator and select Create -> Property Node -> Text -> Text Colors -> BG Color. Change it to write and wire a number of the color you want to use.
Message Edited by Giedrius.S on 02-05-2010 03:20 PM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(7,949 Views)
It was so simple...Thanks alot..
(7,910 Views)
Instead of a numeric, wire a colorbox constant (or control) to the property node. Makes the diagram easier to read. 😉
(To make things even easier in the future, please vote for my related idea here. :D)
(7,898 Views)
Yes I've already used colour box constant.Thank You.
(7,886 Views)
