‎01-04-2007 02:17 PM
‎01-04-2007 03:05 PM
‎01-04-2007 03:18 PM
‎01-04-2007 03:22 PM
You very smart Lynn
Excellent suggestions
‎01-04-2007 03:34 PM
‎12-09-2014 04:55 AM
johnsold
''One is to always sample at the faster rate and simply discard the unwanted data to get the equivalent of the slower rate. If your computer is not too busy to keep up this approach may be more convenient than reconfiguring the sampling.''
can i ask what you mean by discard the unwanted data, this is for changing number of samples on the fly.
‎12-09-2014 05:36 AM
First thing: You are replying to a way old thread, which is not encouraged.
To your question: Discard the unwanted data also means take only the required data. So in an acquisition of 1KHz signal if my requirement is just 10 Hz I can take one sample with an interval of 100 samples. This may or may not be averaged based on the requirement.
