How to changel initial value of one global parameter
Hi all,
Thanks for your time in advance.
I changed the initial value of a global parameter from 0 to 4 and then saved the VI. However, everytime I reopened the VI file, the initial value went back to zero. Any ideas?
Thank you.
(2,857 Views)
Accepted by oly
Before saving, try selecting 'Edit -> Make Current Values Default'
(2,850 Views)
For Labview 6.1, it is under Operate---Make Current Values Default...
Thank you!!!!!!
(2,836 Views)
