How to check CPU usage and Paging using LabVIEW
Hi Guys,
I have to build an application which is used to check the CPU usage and Paging using LabVIEW. How do i do it??
any help, suggestion or hints will be greatly appreciated..
Prashant
(4,161 Views)
Accepted by Prashant.C.S
If you are planning to design your application for Windows you can use the .NET classes. (System.PerformanceCounter), there is a simple example shipped with LabVIEW :
C:\Program Files\National Instruments\LabVIEW 2010\examples\comm\dotnet\SimpleTaskMonitor.llb
Also you have several VIs that you can use to check infos about the processor.
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(4,149 Views)
Hi Maxime,
Thanks for your help. Is there any other method so that i don't use .net classes and still achieve it?
(4,131 Views)
Maybe you can use the Windows API too (system DLL, etc), but it will still depend on your OS. You can use the Conditional Disable Structure to make it usable with other OS if you know how to do it (Linux, MacOS, etc).
Da Helmut
(4,114 Views)
