How to connect this
I just want combine three signals together then show in the graph, how to do that?(Not three separate waveform)
Message 1 of 19
(3,994 Views)
You need to use the Convert from Dynamic Data node and then build the array. Look at the attached screenshot
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 19
(3,987 Views)
The waveform shows in graph is separated(3 sine waves), how to show a mixed waveform?
Message 3 of 19
(3,981 Views)
Accepted by LeoLiu
Well, double-click on Convert from Dynamic Data and choose '1D array of scalars - automatic' for all three of them. Then, right click on build array and make sure Concatenate Input is checked.
Adnan Zafar
Message 4 of 19
(3,974 Views)
But the waveform is different with the one I got by using Multitone Generator.vi,why
Multitone Generator.jpgthis is output from Multitone generator.vi
Message 5 of 19
(3,962 Views)
Can you post your original VI? I can then tell you what you might be doing wrong.
Adnan Zafar
Message 6 of 19
(3,958 Views)
I attached my vi, please modified this , thank you
Message 7 of 19
(3,955 Views)
I think maybe you want a Chart, not a Graph, and use Bundle which will show three thinks at once, as opposed to combining three things. You got what you get based on your original question.
Richard
Message 8 of 19
(3,942 Views)
Could you just modified based on my vi? beacasue i'm not quite know how to do what you said, thankyou
Message 9 of 19
(3,939 Views)
Multitone generator does a sum of the waveforms. Replace the build array with a compound arithmetic and add all three.
Message 10 of 19
(3,924 Views)
