‎06-23-2009 07:53 AM
Hello!
I have a product named: Trackerpod (http://www.trackerpod.com/TCamWeb/productdes.htm).
Its a device to tilt and turn a webcam.
I want to controll this device with Labview...
Is there any possilble way for it?
Thanks:Kolos
‎06-24-2009 01:48 AM
Hi
This device is not directly supported and I also haven't found any info on any tries to run it. You will have to program it yourself then. You basically have 2 options here:
1/ Use low-level VISA functions to communicate through USB. You will need to find out on how this device works (how to format commands)
2/ I suppose that the manufacturer provides you with some drivers and/or control software for that. If those are DLLs you can try to call them in LV and use the device this way.
Let us know if you've managed to get it working
‎06-24-2009 03:22 AM
Hi!
I found some code in C !
http://thirtysixthspan.com/TrackerPod/
I think with this TrackerTools-1.3.0.tar.gz or with this TrackerTools-1.0.0.tar.gz i can controll it.
And as i know LabView support C codes. Just i don't know how to use C-code in LabView... Is there any tutorial for it?(i dind't find)...
Thanks: Kolos
‎06-24-2009
03:29 AM
- last edited on
‎07-21-2026
12:49 PM
by
Content Cleaner
Hi
Here is a bunch of links which might be helpful:
Can LabVIEW C?
https://www.ni.com/en/shop/labview/can-labview-c-.html
Building a DLL with Visual C++
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1OvCAI&l=en-US
Using Existing C Code or a DLL in LabVIEW
http://decibel.ni.com/content/community/first/blog/2009/02/10/using-existing-c-code-or-a-dll-in-labview
Let us know how did it go
‎06-25-2009 04:59 AM
Can't i directly write C code in Labview? Do I need DLL-s?
Thanks:Kolos
‎06-25-2009 05:10 AM
‎06-30-2009 08:22 AM
Hi!
In the c files i wan't to complie into DLL there are some include like:#include <linux/kernel.h>
But i have just windows...
Is it possible to make it somehow?
‎06-30-2009 09:07 AM
Hi
The webpage you are linking to says: "TrackerPod Drivers for Linux" so those are linux drivers. Theoretically you could try a Windows Linux/Unix simulator (like Cygwin) or to recompile them for Windows. However, both of those are quite complicated and don't guarantee it will work.
Maybe you could also find the part of code responsible for communication/control itself and appy it in a Windows program? You have to figure out what commands are being sent/received.
You could also ask the producer if they can provide you with any specification or drivers.
Let us know how it goes.
‎07-01-2009 03:40 AM
Ok the DLL problem is solved...
I was so blind...
http://www.trackercam.com/TCamWeb/API.HTM
Here is an exe file, what make me the DLL...
‎07-01-2009 03:52 AM
Hi
Don't worry, I was also looking through their website and also didn't see it.
Let us know if you manage to get it working. If you elaborate a nice LV driver, maybe it's worth posting it somewhere?
