How to convert VIs backward(from 8.5 to 8.2)?
For some reason my installation of LV 8.5 didn't work correcly and I only have
a version 8.2 that I can use, but I can't open the VIs with 8.2 because they have
been made with 8.5. Is there a way to convert the VIs backward?
No need to help me on the installation matter, I have already contacted NI on that.
It will propably take at least till tomorrow before I get that fixed up, so I would like
to work with the previous version in the meanwhile if possible.
Thanks.
Message 1 of 9
(3,592 Views)
There is the File -->> Save for Previous Version option in the menu. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 9
(3,591 Views)
Thanks for your reply Partha.
I didn't mention in the first post that can't use version 8.5 at all, because
of the error in installation. I can only use version 8.2 and the VIs are done
with 8.5. Is there a way to make the conversion, or should I just wait to get
the installation fixed up?
Message 3 of 9
(3,588 Views)
I think you ve to wait till the installtion gets completeted GOOD. Smiley Wink
Message 4 of 9
(3,579 Views)
OK, thanks.
Message 5 of 9
(3,577 Views)
Kindly update here about your results tomorrow.
Message 6 of 9
(3,573 Views)
Sorry, I don't understand what do you mean. Hopefully I'll get version 8.5 working tomorrow,
so I can open the VIs with that. I don't understand what to report.
Message 7 of 9
(3,569 Views)
Thats what I meant to say...
Whether your installation runs & completes smoothly & you re able to open the VIs.
Message 8 of 9
(3,564 Views)
I got the installation finished on Friday, I just forgot to report here,
because of excitement Smiley Very Happy Sorry about that.
The installation failed mostly because of my own mistake.
Thank you again Partha for your help.
Message 9 of 9
(3,519 Views)
