How to convert a large number to hex without truncating to 32-bit.
 I am trying to convert a very large number to hexadecimal (string). The number gets truncated to 32-bit, which is not what I want. For example, the number 28037546508295 (double) should be 0x198000000007. Labview truncates it and the resulting string is 0x7FFFFFFF, using Number To Hex String.vi. I am stuck. Thanks.
Message 1 of 9
(5,122 Views)
Accepted by habsfan
"Number to Hexadecimal String" accepts only I32 data. So you should see a red coercion dot when connecting your floating point number.
You have to use "Format Value" (also in the String >> String/Number Coercion-palette) and use "%x" as format string.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(5,117 Views)
Did you try
"To Unsigned Quad Integer"
Omar
Message 3 of 9
(5,115 Views)
 I should clarify a bit. The Format Into String.vi works in Labview 10. I have a need to use Labview 7. I cannot get it to work using Format Into String.vi. Thanks for the help.
Message 4 of 9
(5,104 Views)
Here is a LV9 Snippet of a method that should be LV7 friendly.
Message 5 of 9
(5,081 Views)
You can split your dbl into two 32bit integers using quotient&remainder (divide by 2^32 followed by "toU32"). Now format each with %032x and concatenate the strings. Remove leading zeroes if needed. (Sorry, posting via phone. I can show an example later)
Message 6 of 9
(5,079 Views)
  An example would be great. Thanks.
Message 7 of 9
(5,049 Views)
  I don't believe Labview 7 uses the $ format character. Thanks.
Message 8 of 9
(5,044 Views)
Mostly a way to pull off a few tricks and avoid crossing wires.  Here is a $-free version, I changed the constant to 2^32, I had the original code for working with 48-bit numbers should have looked more closely.
Message 9 of 9
(5,038 Views)
