How to copy and paste a txt file to different directory
It looks very simple. I used the "copy" from the advanced file function. It worked fine until I created a standalone one. It gave error and did not do what it did.
Any idea?
Opt_Ottawa
Message 1 of 9
(8,205 Views)
Hi Opt_Ottawa,
please explain a bit more. What did you made? Which error did you get? Maybe you can post your code or a picture of it.
Mike
Message Edited by MikeS81 on 03-11-2009 09:36 PM
Message 2 of 9
(8,201 Views)
see this VI.
Phil
NTA-Automation
Philippe B.
Certified Associate Developer / Dépt Moyens d'essais
www.ingenia-system.com
Message 3 of 9
(8,195 Views)
Hi Phil,
which error did you get and when did you got it? Did you build an executable?
Mike
Message 4 of 9
(8,188 Views)
Accepted by Opt_Ottawa
Perhaps you're having a path issue.  Recall that when you build your program into an executable the executable file is added to the path and you end up with one more Strip Path required to get where you were during development.
Did you get an Error 7 occurred at New File?
Jim
Message 5 of 9
(8,150 Views)
If you get error 10 try this.
Message Edited by t06afre on 03-12-2009 01:18 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 9
(8,141 Views)
Hi Opt_Ottawa,
What version of LabVIEW are you using?   I tested it in LabVIEW 8.6 with just a copy in the VI.  It worked fine in both the development environment and as an executable.  What error are you seeing?  Can you attach a screenshot of your VI?
Best Regards,
Bryan H.
Message 7 of 9
(8,112 Views)
Thanks for all. it's working now. The file path makes a difference.
Opt_Ottawa
Message 8 of 9
(8,108 Views)
Please mark Jcarmody's post as solution to your problem that will help others who may face same problem like yours and searching for a proper solution. You can do it by selecting solution from the options menu at the top right corner of Jcarmody's post. Hope you understand.
Mathan
Message 9 of 9
(8,087 Views)
