How to do logrithmic interpolation like Labview Graph?
Hi
I have a question about  interpolation logrithmically.For example I have a line which has only 2 points
(584,7.21)
(14137,0.08)
so when you show this it on the graph,you'll have a straight line on it.But with different Y mapping,the point indide this line is totoally different.
See pics below.
Inside this line,I sample a point at X=6000,but get a totally different Y, they are about 1.2 and 4.3.
Value 4.3 can be get easily by the vi "Interpolation 1D array" ,which is a linear interpolation.
But how to get the value 1.2 ? Thus how to interpolate a array logrithmically?
How does Labview graph calculate this? or Is there a way to get the data from the graph,although there is actually no data at X=6000.
Appreciate your opinion on this.Thanks.
(4,370 Views)
Accepted by avater
You can put the Y values through a log function before you interpolate, then 10^x the resulting Y value. I'm not aware of a native logarithmic interpolation.
Ian
LabVIEW since 2012
(4,356 Views)
It works.
Thanks very much.
(4,349 Views)
