How to draw these inverted triangles ?
    Could you please show me how to draw these inverted triangles shown in the screenshot? Thank you very much!
Payne
(3,718 Views)
Those are called "Shift Registers", they are achieved by running a wire to a for or while loop, right clicking on the tunnel and selecting "Replace with Shift Register"
(3,699 Views)
Accepted by Payne
That is a shift register.  Right click on the border and pick Add Shift Register.
I would recommend you learn more about LabVIEW from here. How to Learn LV
(3,697 Views)
Thank you. Also, how could I draw the green one shown on top? ( Which property do I need to change ?)  Thanks.
(3,671 Views)
The same way.  The color just means what data type it is which is determined by the wires you wire into it.  Green is boolean.  Blue is integer.
(3,660 Views)
