How to find first non zero value from the numeric value or string?
Hiii, Every body
          I have one numeric indicator in which some valuse is coming with the decimal value, lets say 0.00013, now i want to find the first non-zero value from this numeric indicator, then what should i do to do so? i have converted it in the string, but i could not find any method to find first non-zero value from that string or either from the numeric indicatorSmiley Sad????
      Can you please help me, how to do it? i have attached the vi and write all the description inside.
Thanks in Advance,
Nisahnt
Message 1 of 10
(5,235 Views)
You can use the Match Pattern function with [1-9] as the expression. The help for Match Pattern includes many examples on how to use it.
Message Edited by Dennis Knutson on 05-10-2006 07:56 AM
Message 2 of 10
(5,230 Views)
Hiiiii, Dennis
                     Thanks for the prompt reply and i ve got what i want, thanks.
                    But can you explain me what this function will do? will it find the offset of the first number from 1-9?
Nishant
Message 3 of 10
(5,218 Views)
Anybody wanna see the REALLY ugly solution?
Anyway, experience tells me there's a fair chance that this isn't really what you're after. What's your end goal? LabVIEW has some surprising answers: the trick is in knowing the correct question!!
Message 4 of 10
(5,208 Views)
As the help explains:
offset past match is the index in string of the first character of after substring. If the function does not find a match, offset past match is –1. The offset input and the offset past match output might be equal when the empty string is a valid match for the regular expression. For example, if regular expression is b* and the string input is cdb, offset past match is 0. If string is bbbcd, offset past match is 3.
Message 5 of 10
(5,198 Views)
Just convert it to an exponential string and take the first character ;).
Message Edited by altenbach on 05-10-2006 08:00 AM
Message 6 of 10
(5,199 Views)
This only works for positive numbers of course. If the number is negative, grab the second character.
Message Edited by altenbach on 05-10-2006 08:26 AM
Message 7 of 10
(5,183 Views)
Hiii, Altenbach
             Thanks for the reply.
             Actually i made a mistake when i wrote the initial question in the post, i want the position offset of the first nonzero value, can you please do it for me? and with considering if number is negative...
Nishant
Message 8 of 10
(5,164 Views)
Use Dennis's solution and connect to the offset output of the "match pattern" function. You should easily be able to calculate the position you need.
Message 9 of 10
(5,162 Views)
Hiii, Altenbach
                   Thanks for the prompt reply, simply i use your idea in Dennis's solution and i ve got what i want.
Nishant
Message 10 of 10
(5,158 Views)
