How to find index of nearest value in array
i have a double-array A and a double value B.
How can i find out which number in the array A is the nearest number to the number B?
Thanks for help
Message 1 of 8
(8,563 Views)
There's a few different ways to do this. The most efficient will depend on the properties of array A.
Is array A sorted? If so, I think a threshold and final compare will be your best bet.
If not, you can brute force it by calculating a distance array and taking the min value from there.
Message 2 of 8
(8,552 Views)
The array-size is only 10 values.
How do i calculate a distance -array?
Message 3 of 8
(8,550 Views)
I guess I'd do this as a distance squared array.
distance squared array = (A-B)^2
Then do a Min-Max on the distance squared array to find the index of minimum distance. That index on your A array is the closest numeric value to B.
With just 10 values, your other alternative would be to sort A, then do a threshold of A using B to find the transition index. Compare either side to find the minimum.
Message 4 of 8
(8,544 Views)
You aren't giving many details, or answering the questions already asked.  But still I think this is easy enough.  As mentioned if the arrays are sorted you can probably optimize it.
Message 5 of 8
(8,539 Views)
Thanks you for trhe example.
My B is only a value, not array. Only A is an array.
Message 6 of 8
(8,529 Views)
Hi One,
you already have more than 700 messages in the forum so I guess you already left the "absolute beginner" status (regarding LabVIEW) behind you.
But still you are not able to calculate the minimal difference of an array and a scalar number?
Message 7 of 8
(8,521 Views)
Accepted by OnlyOne
If the array is sorted, the built in function "Threshold 1D Array" might work for you.
Message 8 of 8
(8,460 Views)
