02-26-2020 08:43 AM
@Henrik_Volkers wrote:
Here is my try 😉
remove mean, detect zero crossings , slice the wfrm, fit a polynom (migth be better ones) , get the endpoints
It's great that this worked, but in GerdW's defense I feel like removing the mean and looking for zero crossings is the same as using a threshold detection with the mean value, no?
02-26-2020 01:01 PM
Here is my try 😉
Yep, that`s equal, ..
Gio, if you post some critical data, maybe someone comes up with a better idea.
02-26-2020 01:21 PM
As ico82 intimated, the second derivative rapidly changes sign at point 2 before going to zero again, so one does not require a threshold to detect this change. . .
02-26-2020 01:29 PM
Maybe:
Detect the falling slope (mean ...)
use peakdetect with 3 points to get the next valley
do a lin fit for next n (100) noisy points
for the rising edge just reverse the data ....
as always: look at the data, analyse how you detekt the point, draw it in dataflow 😄
02-26-2020 01:39 PM
I have not run the code I am just looking at the graph. Based upon the plot it appears that point 2 occurs unambiguously when
a) the second derivative changes sign from negative to positive
b) the first derivative is positive before the sign change
