How to fit data to a gaussian distribution in Labview 7.1
I am trying to find the FWHM (full width at half maximum) of particles in an image using Labview 7.1.  In order to do so I need to know how to fit a set of data to a normal (gaussian) distribution in Labview 7.1.
(5,827 Views)
Have you tried the Gaussian Peak Fit.VI ?
The LabVIEW help extensively covers how to use this function. I think it is very good, you should give it a shot.
Cory K
(5,816 Views)
I think that must be a later version of Labview.  I have Labview 7.1 and that function is not available
(5,796 Views)
Try the links in my old post here. See how far you get. 🙂
(this is for LabVIEW 7.1 or older. In newer versions, things are significantly easier).
(5,792 Views)
