How to generate random numbers with a known distributi​on f(X)=(8X^2 + 1)*Exp( -X^2 ).
I need to simulate a random number generator which can generate numbers X with the probability distribution of
 f (X) = ( 8X^2 + 1)*Exp ( -X^2 ).
This distribution is not a common distribution.
I have searched a lot, but I still do not know how to realize it.
Thanks a lot!
Message 1 of 12
(4,629 Views)
The distribution (or histogram) is shown in this figure
The random number what I expect is like this
How  to  simulate this random number?
Message 2 of 12
(4,623 Views)
Message 3 of 12
(4,615 Views)
Genererate a random number and insert it into your formula. 🙂
f (Random(X)) = ( 8X^2 + 1)*Exp ( -X^2 ).
The calculation and randomization can be found under Numeric menu.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 12
(4,590 Views)
If you have a given distribution function, you can simulate matching random data by thesholding into the normalized integral of the function with a plain random number 0...1
See this example for more detail. (also look at the links)
In your case you need to decide on a useful range (e.g. -10...10), because your function goes to infinity on both sides. (Since you have negative values, you would also need to shift everything in the positive range (e.g. add 10) and then correct for the shift later.)
However, since your particular function is symmetric around 0, you can simply simulate the positive half (0..10), then switch sign with a probability of 0.5.  Should not be too hard.
See how far you get. Good luck! 🙂
Message 5 of 12
(4,584 Views)
To  Yamaeda,
Thanks a lot for your advice!
I tried but this simple program ran very slow.  And the result seemed not to be what I expected.
Message 6 of 12
(4,554 Views)
To  ,
Thank you very much for your beautiful program!
I tried your method,  but not succeed.
My difficulty now is how to change distribution based on X axis to Y axis.
Would you please help me?
My results is  here
Message 7 of 12
(4,549 Views)
Accepted by laoda
Don't forget to index back into the original X array for correctly scaled data. Here's a simple example (LV 8.0):
Seems to work just fine. 😄
Message 8 of 12
(4,536 Views)
Dear ,
Thank you so much!
 My problem solved!
Message 9 of 12
(4,504 Views)
Message 10 of 12
(4,497 Views)
