How to get Excel Workbook CustomDocumentProperties?
Anyone knows what is the datatype returned from this property node?
George Zou
Message 1 of 12
(8,475 Views)
It should return a collection of document properties, which can be indexed.  Not sure why you are seeing a variant.  Maybe there is some way to cast it back to what you expect, using the Variant to Data VI.  However, I haven't been able to get anything to work yet.
aputman
Message 2 of 12
(8,447 Views)
Thanks for reply.
It probably is a version compatible issue.
What version are you using?
I'm using Excel 2007 on Windows 7 Pro. 64 bit.
I've tried LabVIEW 2011-2017.
I can cast it back to a ref. without getting any error,
but can't use the ref. for any properties or invoke node.
Error -2147352573.
I'm not using RGT, just ActiveX.
George Zou
Message 3 of 12
(8,444 Views)
I get the same error
Excel 2010 on Windows 7 Pro 64bit
Labview 2012.
I tried to cast it to Excel.CustomProperties and Office.DocumentProperties and neither of those work.  There is a VI here (credit: Ben64) where he adds a VBA routine to a Word document via ActiveX and calls it to modify the custom properties.
Technically RGT is just a bunch of ActiveX calls wrapped in nice, pre-packaged VIs.
aputman
Message 4 of 12
(8,436 Views)
CustomDocumentProperties probably returns a variant because the custom properties can be of different type (text, number, date, yes or no). The following code should theoretically works. The type output can be use to convert the variant value to the proper datatype.
I specified theoretically because from the office pc the count property returns 0 Excel 2013) and from the home pc I get error 3008 (Excel 2010).
The Office.DocumentProperties class should be used, the Excel.CustomProperties class relates to worksheet object metadata.
Ben64
Message 5 of 12
(8,416 Views)
I have Excel 2007.  I got error 3008 too.
George Zou
Message 6 of 12
(8,403 Views)
I'm not good at VB.
How do I return a string?
I tried this:
    Private Sub DefineXLProperties(Title As String, value As String by ref)
    value = ActiveWorkbook.CustomDocumentProperties.Item("Title")
    End Sub
and I got error: -2146827284 when I call "Excel Run Macro.vi"
George Zou
Message 7 of 12
(8,393 Views)
I simplified VBA code, still get same error.
Looks like VBA can't return a value.
George Zou
Message 8 of 12
(8,366 Views)
Accepted by zou
I got it !
Since VBA Sub can't return a value, export it to clipboard.
However, the value is not updated from SharePoint Server ! 😞
When use "ContentTypeProperties" instead of "CustomDocumentProperties", it works !
and easy. 🙂  No VBA macro needed, just ActiveX.
George Zou
Message 9 of 12
(8,349 Views)
This doesn't work for me. As you said a Sub can't return value so instead I had it wrote the custom properties to a new worksheet, got the data using Excel Get Data.vi and then deleted the new worksheet. A bit ugly and twisted but it works well to get all the custom properties.
Ben64
Message 10 of 12
(8,337 Views)
