How to group consecutive equal values from an array X and compute the average of the corresponding values in an array Y?
Hi altenbach,
This is a cool solution to my problem, although the nonlinear model of the curves I generate, comes from quite a variety of different sources, like BJT, JFET and MOS and the I-V characteristics of those transistors are piecewise-defined functions, with different behavior in each region so it makes it hard to do define a correct nonlinear model.
So I'm trying to get around by finding a way to an classical approach of averaging the data, is there some resources about it in the forum?
Thank you sincerely,
Wen
Message 11 of 14
(970 Views)
This is a very simplistic way to average before plot. To every point, grag a subarray and average the data. Then plot XY.
Message 12 of 14
(955 Views)
Accepted by Whens_Wens_Day
@Whens_Wens_Day wrote:
Cordm's solution looks amazing but I don't really understand your data flow.
What are the inputs for the sum_grid_values? And the cluster of arrays you introduce in Inicialize array is the sorted and deduplicated X values? And the other 2 inputs? Can I have a look of the vi?
Wen
The input tunnels from top to bottom are x, y, {sum, n} cluster array for summing y values for the same x, and the x-grid. Look at the wires with probes to see what is going on.
Threshold 1D array finds the closest match to the x-value on the grid, which is used to index into the summation array.
The LV 2019 version includes the map version, the LV2012 version does not.
Message 13 of 14
(944 Views)
A polynomial of sufficient order as shown can fit anything and does not need any theory.
You can create a VI that uses different nonlinear models based on the input. Right now, all you do is cosmetics. A real model would provide you with relevant parameters that have meaning!
("Piecewise" in nature is rare. Often a suitable model can do all regions at once. Your problem is that both x and y are quite noisy and fitting typically assumes noiseless x)
Message 14 of 14
(927 Views)
