How to hide indicators based on case values?
I'm trying to show some of the indicators only where appropriate -- the derivative graph when testing a resistor, and the semi-log excerpt graph for testing a diode.  I'm also not sure I've excerpted the characteristic portion of the diode accurately.  (The case structure bit is all the way off to the right; everything else works.)
Thanks!
Message 1 of 10
(4,191 Views)
use the visible propery
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 10
(4,190 Views)
I've looked at several similar threads that talked of the visible property, but I'm not sure I've used it correctly, and I can't test it from home -- no DAQ board.
Thanks.
Message 3 of 10
(4,188 Views)
right click your indecator go to create->property node->visible you might not need to use a case structure instead you could use a select.vi
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 10
(4,184 Views)
I've created the property node = Visible, but I can't find how it works (or I can't understand the written directions).  Any pictorial references you might mention?  Thanks.
Message 5 of 10
(4,174 Views)
Accepted by Emm
here is an example:
the visibility function is a simple bool
Message Edited by Harold Timmis on 11-15-2009 05:44 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 10
(4,157 Views)
Think I've got it, thanks!
Message 7 of 10
(4,146 Views)
I suggest to simplify further and delete the "select" and the two boolean diagram constant. If you wire the switch directly to the property node, it will function the same.... 😄
(see also).
Your other VI (visibiliy.vi) is also not that great. Since the property node exists in both cases, it belongs after the case structure (only one instance is needed!). The loop needs a wait, and the property node should only get written when the boolean changes, and not with every iteration of the loop.
Message Edited by altenbach on 11-15-2009 10:00 PM
Message 8 of 10
(4,122 Views)
wow, I rubed that one lol
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 10
(4,076 Views)
I put all the Visible Property Nodes outside my case statement, and put too Boolean Constants inside each one.  True was wired to the Diode indicators for the Diode Case, and False was wired to the Resistor's indicators.  I reversed the constants for the Resistor case.
Message 10 of 10
(4,024 Views)
