How to implement logical equation as LabView?
I have this bit test logic I need to implement as a Labview code.
Should I use formula node or either something similar to this already in Labview?
"((var & (1<<bit)) != 0)"  where 'var' may be 8, 16, or 32bit, 'bit' is a number 0 - 31 representing
a bit number. 0 is the least significant bit.
Thank you,
Do
(3,353 Views)
Accepted by horanyee
Rotate, And, Not equal to zero
Message Edited by Ravens Fan on 08-10-2009 09:36 PM
(3,340 Views)
You could use a formula node or just a bunch of math nodes.  Either will work.
The only really "tricky" part (and it's not that tricky) is the bit shifting.  Just use 2^bit instead of 1<<bit
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,337 Views)
Just saw your post Ravens Fan.  Didn't think of a rotate, but that (of course) would work.
-Matt Bradley
(3,336 Views)
