How to know if a sub-VI connector is linked? / Détecter si un connecteur est raccordé
Good morning,
I develop under LabVIEW 2009 SP1, I have a sub-VI with facultatives connectors and I shall want to do operations so if the connector, in relation with,  is connected. I shall be able to use a Enum input to now what I want to do, but I would like to make simpler
The question is:
Is it possible to know, in a sub-VI, if a facultative connector (input) is connected when it's called?
Thank you for your help
Bonjour,
Je développe sous LabVIEW 2009 SP1, j'ai un sous VI avec des connecteurs facultatifs et je voudrai réaliser des opérations que si le connecteur en question est raccordé. Je pourrai utiliser un énum de commande pour indiquer ce que je veux faire, mais je souhaite faire plus simple.
La question est:
Est-il possible de savoir dans un sous VI, si un connecteur d'entré facultatif est raccordé à l'appel  ?
Merci pour votre aide
(2,726 Views)
There's no existing method for detecting this. The simplest is to add an invalid value and make that the default (see here for an example).
See here for an explanation of why this will probably not be implemented.
___________________
Try to take over the world!
(2,714 Views)
Accepted by BGR72
Make the connector Type "Variant" and convert from Variant to the type of control you want inside the subVI - if unwired by the correct input type, you will get error 91
James
Message Edited by James W on 05-21-2010 10:36 AM
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(2,695 Views)
