How to lock " Write to measurement file VI" during run time of application so that file can't be opened during run time.
Thank you GerdW, Nobert & Sam. I will try in that way.
Best Regards
Jamal
Message 11 of 13
(973 Views)
Jamal,
one off-topic note: While we do appreciate kudos (some even might be addicted to collect them!), the general idea of kudos is to mark extraordinary helpful/thoughful posts.
As such, marking all replies you get as "very helpful" reduces the value of these kudos....
Anyhow, thanks for the kudos i got from you, but please start to use them as "reward system" for replies which granted you very useful knowledge. Post which helped to find a solution should be marked as solution.
thanks,
Norbert
Norbert
Expert: Geometry
Message 12 of 13
(960 Views)
Thanks Norbert.
Out of topic: Infact all post  have been  helpful and thoughtful to me. Reason of giving kudos is for appreciation to those who are there to reply queries.
Jamal
Message 13 of 13
(953 Views)
