How to make Boolean to Numeric
Hello!
How do I change this code, so that if state one is true, then output number 1. Then if state two is true then output 2 in numeric.
Thanks in advance.
(4,522 Views)
What if both inputs are TRUE?  And what about H3?  Maybe a simple truth table would help narrow down exactly what you are trying to do.
(4,507 Views)
Given three switches, there can be a total of eight possible states. You only have 6 LEDs.
Please clarify the problem and provide a full truth table as requested.
Also note that you probably could dramatically simplify your code by using arrays as controls and indicators.
(4,497 Views)
One possible interpretation...
(4,485 Views)
Okay, maybe I expressed myself wrong. It is true that there are 8 possible states, but they are not intresting in what im trying to do. The thing i want to do is output a number instead of a led light. So the led in the top "tillstånd 1" should output 1 in a numeric number.
(4,477 Views)
Wire a numeric indicator to the output of "boolean array to number". Right?
(4,471 Views)
Accepted by Westen
If only one LED can be TRUE, do "search array" for true and display the index (-1 if all are off).
Depending on how you want to count, add a +1 if needed.
(4,469 Views)
