How to make X-channel decreasing using chart?
So then don't keep trying to use a chart.  Use an XY graph.  The one thing you will need to do is maintain a history of what was already placed into the graph.  A quick way to get started is to use the Build XY Graph express VI.
Message 11 of 25
(1,768 Views)
you dont know the answer so please leave this topic.. I have to do  it on chart I couldnt change the program however I want. IT MUST BE A CHART!!!!! you still dont get it...
Is anyone else  could help me?
Yasemin Barutçu
Electrical And Electronics Engineer
Message 12 of 25
(1,760 Views)
Please behave!
Send us the VI you saw with chart, so we can take a look at it, or ask the person who created it.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 13 of 25
(1,754 Views)
If I had to chance to upload it here , I did but I dont have a permission
Yasemin Barutçu
Message 14 of 25
(1,746 Views)
Try to use winzip or something. Also the filesize limit is 4MB I believe
Even
Topro AS
Norway
Message 15 of 25
(1,743 Views)
I cant share this programme thats why I couldnt upload..
Yasemin Barutçu
Message 16 of 25
(1,738 Views)
You don't get it.  IT CAN'T BE A CHART!
Who says it must be a chart?
Apparently, you don't have the ability to actually listen to what is being told to you.
So I will leave this thread.  Good luck getting anybody to help you after your rude response!
Message 17 of 25
(1,736 Views)
@No_RegreTs wrote:
And I said earlier. I saw that happens...........................................
Maybe you saw a chart with the right side of the X axis set to zero.  If you drop a waveform chart and change the right value of the x axis to zero, the chart will scroll in the opposite direction.
Message 18 of 25
(1,694 Views)
You can also change the Display Format for the X-axis to include a minus sysmbol to make it look like it is going negative...
Message 19 of 25
(1,690 Views)
but x channel going zero to 100. my X channel goes like 533-532-531.. What I want to do is makex channel values decreasing not increasing. What u showed is going just right to left.
Yasemin Barutçu
Message 20 of 25
(1,686 Views)
