How to make X-channel decreasing using chart?
Uhmmmm....
now that we are all calmed down-  Its really not that hard
Silly Snippet
Message 21 of 25
(1,719 Views)
Accepted by No_RegreTs
The boolean property that Jeff shows actually controls whether new values are added to the left or right side of the chart, the original problem of the chart disliking descending x-values still persists.  My solution is two-fold, negate the x-values fed to the chart and set the x-scale multiplier to -1.
Message 22 of 25
(1,686 Views)
First thank you for your interest. I tried your method but it didn't work. But Darin.K's method works.  Thank you very much Darin.K. Thank you both
Yasemin Barutçu
Electrical And Electronics Engineer
Message 23 of 25
(1,644 Views)
Wow I didnt know you could do that!
Thats because I have always used a Waveform Graph for doing that job!
Craig
LabVIEW 2012
Message 24 of 25
(1,624 Views)
There is always different way. should not be single-minded I guess. 🙂
Yasemin Barutçu
Message 25 of 25
(1,594 Views)
