06-20-2011 04:10 PM
So then don't keep trying to use a chart. Use an XY graph. The one thing you will need to do is maintain a history of what was already placed into the graph. A quick way to get started is to use the Build XY Graph express VI.
06-21-2011 12:54 AM
you dont know the answer so please leave this topic.. I have to do it on chart I couldnt change the program however I want. IT MUST BE A CHART!!!!! you still dont get it...
Is anyone else could help me?
06-21-2011 03:14 AM
Please behave!
Send us the VI you saw with chart, so we can take a look at it, or ask the person who created it.
06-21-2011 05:31 AM
If I had to chance to upload it here , I did but I dont have a permission
06-21-2011 06:17 AM
Try to use winzip or something. Also the filesize limit is 4MB I believe
06-21-2011 08:05 AM
I cant share this programme thats why I couldnt upload..
06-21-2011 08:19 AM
You don't get it. IT CAN'T BE A CHART!
Who says it must be a chart?
Apparently, you don't have the ability to actually listen to what is being told to you.
So I will leave this thread. Good luck getting anybody to help you after your rude response!
06-21-2011 12:35 PM - edited 06-21-2011 12:36 PM
@No_RegreTs wrote:
And I said earlier. I saw that happens...........................................
Maybe you saw a chart with the right side of the X axis set to zero. If you drop a waveform chart and change the right value of the x axis to zero, the chart will scroll in the opposite direction.
06-21-2011 12:42 PM - edited 06-21-2011 12:45 PM
You can also change the Display Format for the X-axis to include a minus sysmbol to make it look like it is going negative...
06-21-2011 12:45 PM - edited 06-21-2011 12:46 PM
but x channel going zero to 100. my X channel goes like 533-532-531.. What I want to do is makex channel values decreasing not increasing. What u showed is going just right to left.
